RCU Forums - View Single Post - 9303 Programming Gyro Sense on a 6 channel Rx
Old 07-01-2005 | 08:47 AM
dsnyder's Avatar
dsnyder
Default RE: 9303 Programming Gyro Sense on a 6 channel Rx
You can use the gear channel and simply use the travel adjust values to set the gain. You can selelct a different switch if you would like in device select.
