RE: H9 Showtime 4D electric conversion
You give up a some efficiency and flexibility with the AXi. The AXi is like a glow engine in that it only works well with a relatively narrow range of props, whereas a geared motor like a Hacker has virtually unlimited prop-spinning capability by simply changing gear ratios. The Hacker/gearbox setup is also several percentage points more efficient, so that much more energy gets to the propeller.
