well i went to the hardware store and got some flanged 8/32 nuts so i can ease my mind..
also one other thing if you are thinking about this plane and are going to skimp on servos. i suggest you look somewhere else... to get mikes recomended 3d rates in the manual ALL surfaces are within Millimeters if banging the trailing edges with a 1 1/4 horn.. im running 645MGs on 6v and am thinking about going for the 5645s allready. you wont hear of anyone going beyond the recommended rates because they are MAXED
I CANT WAIT
with the YS 110 i am almost done. I have balanced it from time to time through the build . the CG has allways been pretty close.. i have not decided wich way i going on rudder yet. i will have to do it very last and then it will just be a matter of moving the battery around for CG (just the way i like em)
So far i havent one bad complaint other than the 8/32 nut deal i explaned before
