RE: Bdavison's E-flite Blade Assembly
Now slide the head onto the main shaft.
Then insert the shear pin into the head to hold it on.
Now snap the paddle control pushrods to the "SHORT" swashplate control arms. The short pins are for intermediate use. Use of the long arms will be addressed in the "Performance modifications section".
Your blade may or may not have long and short control arms, in which case you can use any pair.
Do NOT cut off the extra control arms. If you crash and snap one of the arms, you can switch to the other two. If you remove the extra arms, you will have to replace the entire swashplate.
Well, this completes the assembly.
