RCU Forums - View Single Post - First time flyer
Old 07-03-2005 | 12:33 AM
kobus_uk's Avatar
kobus_uk
Default RE: First time flyer
Hi all
I'm new to the RC community and only bought my Esky Honeybee CP2 two weeks ago. Everything was perfect except that the battery only held through the maiden flight and wouldn't charge after that. Bought a new Li-PO and it's holding out. I have practiced on FMS simulator but I feel that nothing comes even close to the real thing. Although it gave me some Good insight into the maneuverability and controlling of my heli. After a couple of hours on the sim I took on the real thing. I was amazed at this little machine totally in my control but soon realized that patience is a virtue. Evidently I lost my main rotor blades in an unfortunate accident. Almost in tears as I knew the accident could've been prevented. Which leads me to a great tip for beginners. Create an imaginary circle in which you will learn to hover. If for one moment you leave that circle, set down and reposition. Believe me it pays of. It's has only been about 15 10min flights and I'm already feeling much more confident in hovering my little beast. I took it outside today and was surprised on the affect a small amount of wind have on a stable hover. It changes everything. The Honey Bee is definitely a wonderful way to enter the RC universe.
Well as this is a ESky Honey bee Problem forum. This is my problem. I will try to illustrate the problem on someone else's picture that I saved from this very forum. They were not available to ask permission and hope that they will not sue me for it or something like that. Just feel that it would be impossible for my to explain my problem without an image.
Surely hope someone out there will understand what I'm trying to say: Here goes nothing.....
The swash-plate has a pin (#1) that seems to keep it from moving all around. It slides in a groove (#2) when you move the aileron forward and backwards. When I opened my package I didn't realize this until further inspection but this pin was not inside the groove. It was outside moving up and down the right outside edge. I carefully moved the servos down and slipped the pin into place. I was pleased with myself that I noticed this and was eager to fly thinking it might be more stable now. To my surprise it did not have any lift at all. At full throttle it sat dead on the ground. Before putting this pin back where it belonged I could easily lift of at half throttle with the trim also set in the middle. It just seemed to drift left a lot (which I thought was normal because of the tail rotor). It seems that the helicopter was set up at the factory with the pin (#1) out of place because it takes of easily when not in the groove (#2). There is a small pin that holds the fuselage in place that goes through a hole (#3) and because of the swash-plate not being in place as it should be the rod connected to the servo (#5) is rubbing against it causing the servo not to return to it's !QUOT!neutral!QUOT! position. That was definitely a mouthful but I've learned from reading the forums that here's some really experienced RC pilots and builders in here. What can I do to fix this?
I wish this was the end of my problems. Well another thing I noticed and I know that this will affect the performance of my heli is that the cable tie (#4) rubs against the main gear and I'm sure that it must put strain on it to some degree even though it still flies. I've learned from the forums that it's all about fine tuning. Would just like to achieve that. A fine tuned flying machine.
Also not visible on the picture I noticed that my 4-in-1 box is slightly skew to the left but I don't know if this will have any effect on the helicopter.
You must be getting really irritated by all my problems but my last problem and definitely not least is that my tail motor revs sometimes instead of keeping a steady speed, jerking the tail from side to side. I noticed this happens mainly when I adjust the aileron to the right for take-off. I also feel the need to keep the right analog stick ( aileron) to the right during hover because if left in neutral the helicopter dives to the left. I believe that this might be because of the pin (#1) out of place as mentioned earlier.
Well that is all for now and I'll be really glad to get all this sorted out to be able to get back to training. I feel that if I keep training on a defective Heli that I might have problems when it's all finely tuned. Better to get it sorted out quickly.
I am looking forward to your replies and will be glad to help any beginners with my experience gained. Feel free to e-mail me with questions or anything regarding Electric RC helis. Would love to see your maiden flight videos or anything similar. My e-mail address I don't usually give out freely but I feel in the RC Universe we are all brothers.... (and sisters I should add)
My email address is [email protected]
Kobus_uk
