ORIGINAL: carlosponti
RysiuM nice work on the video. i liked what i saw there.
Did you? so how do you take this. I made glow plug adapter for that engine and I run it on glow. The plug was powered all the time from 2 AA 1.2V 1800mAh NiMh batteries. THE SAME FUEL: Motul oil 1:30 with gasoline 93oct (Chevron). Engine run the same like on ignition - even better. I got steady idling at 1600 rpm and 7400rpm at WOT (it is 200rpm more than I got on ignition). I didn't even adjust the needles.
If I decide to keep it like that the engine will be over 1 lb lighter (flywheel and ignition coil with support will be gone). Yes, it was hard to believe. I couldn't believe myself. But it works.
RysiuM
