RE: CEN MT2 Cannot Shift into 2nd Gear
cougartech... If your engine is running correctly and winding out enough it will shift.. if not, it won't.. simple as that... make sure you back off the adjustment screw a little more 1/4 turn at a time after the engine is leaned out... I occasionally cannot get shifting to 2nd until I make sure the engine is running correctly... The mesh being a little off won't make a differnce as long as its not rubbing the spur gears... you may strip a gear but thats about it.. Just tinker with it a bit, once you get it, should be set for a long time... Unless you somehow have hpi parts mixed in
