RCU Forums - View Single Post - Kadet SR ARF Engine Mount Mod?
Old 07-04-2005 | 10:17 AM
jtsails
Default Kadet SR ARF Engine Mount Mod?
I'm trying to figure out the best way to repower my Kadet Sr ARF. I want to mount a OS 52 Surpass 90 degrees to vertical and I have some questions. First, Can I epoxy a piece of 1/2" play onto the firewall and then put the engine mounts on this. The clearance will not be a problem but will it be secure enough? Should I also screw this mounting block to the old blind nuts in the firewall and what is the most acceptable method for securing the mounts to the block, wood screws or should I put blind nuts in the mounting blocks before I epoxy it onto the firewall.
Thanks in advance
