RCU Forums - View Single Post - Fliton EXTRA 330s Freestyle ARF
Old 07-04-2005 | 01:43 PM
  #90
tIANci's Avatar
tIANci
Default RE: Fliton EXTRA 330s Freestyle ARF
YS110 on this plane has been done in Singapore ... one of my pals seen it fly ... her says it rockets out of a hover. Only one issue ... you really need to beef up the firewall and the engine mount box. If you are a 3D fanatic, please take the Saito 100 option, I seen it fly and I wish I could have one, again, the plane needs to be beefed up.
Mine had a Saito 72, its not enough for good 3D ... the minimum should be a Saito 82 on 25% nitro min turning a 14x6 or even a 15x4W. I tried my plane with a TT61 2C and despite having more RPM (both on APC 13x6) than my Saito 72, the Saito was more fun to fly 3D. I am going to try an APC 13x4W to see if it will spool up faster.
As for the push rod on the elevator, it works fine ... mine has easily 40 degrees throw. Hardly any flexing at all.
