RCU Forums - View Single Post - THE RETURN OF THE VIPERJET
Old 07-05-2005 | 09:50 AM
Miguel Santana's Avatar
Miguel Santana
Default RE: THE RETURN OF THE VIPERJET
THE SMOKE SYSTEM (SSS)
As I had mention before, I made my own system with a Pepsi pep bottle and a B&B valve drive by a HS-81 mini servo, all this installed on one of the turbine base mount which I made removable for a good reason (details later).
The round brass plate + the cap is glue to the bottle with hysol....bullet proof.
The panel with the valves + filling air valve is where the smoke system is controlled. Both valve's exits will exit outside at the bottom of the fuselage so no mess is possible inside the plane. Both valve are open to fill the system with the smoke liquid. Then are close to apply 80 psi of air pressure through the air filling valve.
The !QUOT!tank!QUOT!is mounted on top of the front wing former in a base as per the picture.-
Some details bellow, will add more later on.
ID:	293847   Click image for larger version
ID:	293848   Click image for larger version
ID:	293849   Click image for larger version
ID:	293850   Click image for larger version
ID:	293851   Click image for larger version
ID:	293852   Click image for larger version
ID:	293853   Click image for larger version
ID:	293855   Click image for larger version
