Originally posted by Aruba_Maverick
Thanks guys,
If I were to use 2 servos on the stab what would be a good servo
I'm not sure but I heard that some of the top fliers uses 2 futaba digital mini servo on each stab for this setup.
If I use a single setup I think a JR8411 will work. Any comment??
C Lim
A smooth landing will make your day
CPLR (Synergy designer) runs a 9252 with the MK bellcrank (saw it for myself at the WC). I am running the same setup on Evolis, and it works very well.
Futaba does not currently have any mini servos that are digital. If you must use servos in the tail (I really recommend that you dont ) probably the 9602 would be an OK choice for the job.
