RE: Advantages for running seperate air tanks for brakes and Gear
brakes are the most leak prone part of any jets air system. If you get a leak, your gear might not have enough pressure to come back up, worse yet, to come down. I have had brake tanks lose air a few times, such as 2 instances where O-ring seals failed/popped out in the wheel/brake hub.
Wojtek
