RCU Forums - View Single Post - How to scare yourself AND gain confidence in your plane.
Old 07-06-2005 | 10:48 AM
gboulton's Avatar
gboulton
My Feedback: (15)
Default RE: How to scare yourself AND gain confidence in your plane.
Well, sorta...
The method of mounting the wheels (particularly the tail wheel) described in the instructions just plane SUCKS. All 3 wheels will wobble quite a bit if the instructions are followed, with the tail wheel being the worst...I could get it to wobble as much as 45 degrees off vertical in either direction. Fixed that with a bit of re-engineering and some spacers on the tail wheel...it still wobbles, but not nearly as badly. The mains are pretty straight and true now after some re-engineering.
The plane STILL wants to pull right, but it only tends to do it at or near take off speed, and is less violent and more predictable...I SUSPECT there's simply something about the plane (or my build) that causes this, and the wobbly wheels were making the situation far more violent and less predictable.
I flew it 3 times yesterday, and each takeoff roll...while by no means straight...was 'controlable' and safe...so that's improvement.
Now he REAL question, shakes, is how in the HECK you KNEW about that. I didn't think I'd mentioned it here, so you MUST know me from the field. WHO THE HECK ARE YOU?
