RE: Breaking in an OS LA 40
Your fuel is the right type. I'd suggest a 10-4 prop for break in. This is an ABC/ABN engine. It should be broken in at a only SLIGHTLY rich 2 cycle mode. I'd also suggest a McCoy RC 9 or 59 plug. Run 2-3 tanks through it on the ground, then, if it will hold an idle and transition, fly it.
Dr.1
