Control horn installations..
Installing control horns requiring 3 to 4 screws and a backing plate of some sort can be a bit of a task. Getting all the holes to line and getting the screws started can be a problem. My solution to this is to grind a point on the end of each screw. The screws seem to find the hole in the backing plate much easier this way. Give it a try!
