RE: Help with Engine Problems
The bubbles are leading to the muffler. White smoke comes flows the muffler when reved up for the 5 seconds. It seems to have good flow. I will take it apart and check though. The needle. I am unsure how that works. What I did was tighten it all the way then I turned it to the left about a half turn. I replaced the tubes flowing to the muffler and the carb. The fuel was bought from a hobbytown 10% the red fuel. The tank it self should be good since I replaced it. Not sure if I put it together right, but its doing what it did before I replaced the tank so I assume I atleast got the tank together right. Thanks again for the help.
Brandon
