RCU Forums - View Single Post - Steel Pinions - Threaded for FunFactor c/b
Old 07-07-2005 | 09:57 PM
rolland
Default RE: Steel Pinions - Threaded for FunFactor c/b
Thanks for the info. I am interested in the 14/18 combo. That size should also work well with the OS .18 motor even with maxx size tires if they are kept relatively small.
That .28 motor should be able to handle a 17 or 18 first gear. I have seen a Mammoth at the track with a 16 tooth first gear pinion and it had no problems. The gearing on the Mammoth is 13/47 in the diffs and 60/65 spurs and 11 plus pounds in weight so, with the 38/42's a larger first gear pinion could be used.
rolland
