RCU Forums - View Single Post - CEN MT2 Cannot Shift into 2nd Gear
Old 07-08-2005 | 11:29 AM
cougartech67
Default RE: CEN MT2 Cannot Shift into 2nd Gear
Hey Guys. Trying to get back on topic. I might have figured out what I did wrong, in regards, to my MT2 not engaging the 2nd gear. There is a part, of the transmission, not sure the exact name of the part, but this is where you have the 2 screw locks. One is screwed all the way in to hold the spur gears in place. The other screw is sitting on a spring, then on a little metal ball. This is for adjusting the 2nd speed gear engagement, right? Well, I had left both screws in tight. So I re-adjusted the screw with the spring and ball, i backed it out 1.5 turns out. Will run the MT2 tonight to see if it worked. any other suggestions?? or theory's? Thanks Guys. [8D]
