don't take this the wrong way, but I thought you understood how the trans worked... I said in a past reply to make sure you back off the set screw.... Anyway, that will fix the problem.. now for mine.. Did You put a voodoo curse on mine.. It wouldn't shift yestersay out of first.. The engine was screaming to the point of non stop wheelies but wouldn't shift.. I didn't have an allen wrench on me to adjust it.. just a little 1/4 turn should do the trick...
