RCU Forums - View Single Post - A-10X Preview
Old 07-08-2005 | 01:56 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default A-10X Preview
Thought you guys might like to see a few pics of the new A-10X. I am currently building one, powered by an Artes Bee, to test flight performance and compile the manual. So far, I am quite impressed with the quality. With the exception of some poor glue joints to the fuse formers (which will be corrected on production), the kit is very well made and should be an excellent grass field capable, trainer type aircraft (or, every day beater ). Airframe consits of a fiberglass fuse and booms, built-up wings, center section and stab. Assembly is minimal, really just a matter gear, electronics and engine installation... The kit is designed around the 54 class engines, it is not possible to fit a larger can (ie: KJ66 size) in the mounts. The A-10X will be available in three color schemes and will also be offered as a combo package including retracts, wheels, air support, fuel tank ect...We are expecting delivery of the A-10X in early August.
BTW, not seen in these images but included is a belly pan which has the wheel wells molded into it....
Todd
ID:	295003   Click image for larger version
ID:	295004   Click image for larger version
ID:	295005   Click image for larger version
ID:	295006   Click image for larger version
ID:	295007   Click image for larger version
ID:	295008   Click image for larger version
