RCU Forums - View Single Post - Tachometer Placement on Gas Engine
Old 07-08-2005 | 04:51 PM
dirtybird
Default RE: Tachometer Placement on Gas Engine
ORIGINAL: blueberry
I am new to using a tach also I have the tower hobbies mini digital it was also reading very eratic until I put a incandescint light on the opposit side of the prop aimed at the engine.
Now I get very steady readings. Don't use flourescent as they cycle 60 times a second
your tach will read 3600 rpm soo it may affect your readings below that. Give it a try.
Pete
An incandescint light also cycles 60 times a second if its powered from the ac power. Use a flashlight.
