RE: Showtime
Hi Lee... any idea why the tail wheel springs are breaking?? Are you
thinking of replaceing the tailwheel assy.? Now that you had the tube
problem guess a bit of epoxy may be in order. I do not harrier good
so with the wing rock guess it'll make it even harder for me? Let us
know what you find out on your wing/trim.. Other than what you
have listed how would you rate the plane?? Did you use all stock
hardware? and one more question:-0.... What size spinner are
you using?... I have one on hold.. And money is a bit tight, So
I'm just checking to get all that I need if I complete the order, and
I guess to make the best choice I can in another plane:-)
Thanks for any info
