RE: Wildhare Edge Help
1. Yes but you have to use spacers if using the stock standoffs or you can order them custom
2. No hole is needed for the carb..its rear mounted.. but if you mean for the neeldes then just use a dremel or a drill and make a hole to stick a screwdriver thru..
3. Yes
4. Yes
5. Yes
