RE: Welcome 3D Foamy
Your welcome and I should have clarified couple of points in my first post.
I forgot you were using an out runner motor which is a tad heavier than mine but I need a gearbox which probably evens us out. The Eflight 400 out runner has more power than mine but I may have exaggerated exactly how much. You will defiantly be very happy with the power anyway.
If you decide to epoxy the skins, use something like a flexible credit card to apply it as thin as possible and lay some books or something on top until it dries. Also to get good throw on the rudder, you will need to cut some foam off the elevators. I just cut the corners off making kind of like ½ hex.
Good luck,
Ken
