RCU Forums - View Single Post - Trim Help!
Thread: Trim Help!
Old 07-10-2005 | 08:42 PM
Flypaper 2
Default RE: Trim Help!
Rick:
Way to much upthrust in the engine. Shim the motor down a bit at a time till it will not climb when you add throttle. This is called neutral trim. The wing probably has a bit of a warp in it. For a trainer type plane I wouldn't worry about it although a heat gun may take a lot of it out.
