RCU Forums - View Single Post - BATTERYS, WHAT KIND
Old 07-10-2005 | 10:21 PM
rctom's Avatar
rctom
Default RE: BATTERYS, WHAT KIND
ORIGINAL: SAL98
4.8 will also give you a little longer run time for the same capacity batts because your servos are pulling less amps than at 6volts.
This is a myth. Yes, there is 25% more current flowing and 25% more power being consumed, but you are carrying 5 cells which means 25% more total watt/hours on board so it works out the same.
TF
