RCU Forums - View Single Post - antenna question
Old 07-10-2005 | 11:41 PM
Jimmbbo's Avatar
Jimmbbo
Default RE: antenna question
ORIGINAL: gboulton
While we're on the topic...
If you have an antenna on an older receiver that got cut off, can you solder another piece of wire to the end to restore it to original length?
If so, should the wire be exactly the same guage, or will slightly different wire do?
On a similar vein, how about replacing the existing antenna wire with a smaller diameter wire of the same length? Want to use a smaller dia black wire for warbird antenna....
Cheers!
Jim
