RE: A-10X Preview
Hi Albert,
The CG is 115mm from the leading edge of wing.
Aileron : 30mm up and down
Elevator: 25mm up and down
Flaps : 60mm down
Rudder : 25mm left and right.
I fly with JR10X radio and have the 3 mode setup for flight. After takeoff i switch over and travel is reduced. When i fly from short field (100m) i use full flaps for landings. No bad tendancy. Just remember not to get under the power curve.
The A10X lands very slowly. With a slight breeze you can land her in 50m with no brakes.
Let me know if you need more info. I will post some more pictures as soon as i got the time..
Regards
