Could you go into more detail on this?
ORIGINAL: john leigh
Mike did you notice fuel dripping from the carby at idle? If so, this could be your problem. The main fuel needle comes off from the rocker arm/part of the diagram. This makes the engine run rich at idle and lean at higher revs.
