RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 07-11-2005 | 12:13 PM
  #237
skylab
Default RE: Showtime
Dilled, Are you using a piece of music wire to reinforce the SFG's? If so does this rod connect into the bottom SFG also?
Gerry
ORIGINAL: dilled
We found a new weak point on the Showtime. The Top SFGs are very weak at the base and will break on hard moves that put high loads on them. We pinned the Top SFGs by drilling a hole along side the mounting threaded rod and installed a 1.5" long rod glue in. This makes the top part a lot stronger.
Pat
