RCU Forums - View Single Post - OFFICIAL HPI RUSH / EVO THREAD
Old 07-11-2005 | 05:59 PM
  #97
TonyT944
Default RE: OFFICIAL HPI RUSH / EVO THREAD
hi
Check the little brass nut on the carb to throttle arm. mine had worked loose, just enough to allow the barrel of the carb to be up set - if you went to full throttle it would be ok then would scream when you tried to brake etc
2 min fix - remove fuel tank and get at it with a small socket driver.
Regards TonyT
