RE: Florio Flyer Stunt Wagon Kit
The sheeting adds quite a bit of strength to the wing. A little tip. After you get one side sheeted, prop the wing so it is perfectly level before you sheet the other side. If you put the sheeting on with a bit of a warp, it'll be permanent. You may even want to put in a bit of washout. Hope this helps.
