RCU Forums - View Single Post - Wildhare Edge Help
Old 07-11-2005 | 09:43 PM
mstroh3961's Avatar
mstroh3961
Default RE: Wildhare Edge Help
on the stand offs, If you order the DA from Tom it will come with 3" stand offs. so a 1/4 inch plywood or hard wood shim will get the job done. If you order direct from DA, simply ask for 3" standoffs. They Will exchange them at no cost.
the choke servo is an item of preference. what ever works for you.
servo arms, air wild MLP arms or the SWB arms are the ticket! order 1.25" arms for ailerons and elevators. and a 3" double for the pull pull.
here are some pictures of my install.
ID:	296343   Click image for larger version
ID:	296344   Click image for larger version
ID:	296345   Click image for larger version
