RCU Forums - View Single Post - pull-pull setup (again, sorry)
Old 07-12-2005 | 09:08 AM
Sparhawk's Avatar
Sparhawk
Default RE: pull-pull setup (again, sorry)
FWIW, you need to make absolutely sure that the distance between the horns at the rudder is the same as the distance at the servo arms.
For a non-crossed setup, and everything straight and on the hingeline, this is ideal. But, in your case, the lines are crossed, and I read somewhere that the servo arms need an offset arm if you cross your lines.
Check out this very invaluable info from SWB [link=http://www.swbmfg.com/rudex.html]http://www.swbmfg.com/rudex.html[/link]
Hope this helps.
Spar
