RCU Forums - View Single Post - When do you get a second plane?
Old 07-12-2005 | 05:25 PM
DTB's Avatar
DTB
My Feedback: (15)
Default RE: When do you get a second plane?
ORIGINAL: ScienceisCool
i agree.. i know i'm not ready quite yet but with more practice i should be able to comfortably move on to a low wing plane in about 4-6 months.
as for which plane will be my second.. i think i've settled on the WM T-34. I like the sig 4 star but i really like the looks of the T-34 a little bit better. If i was going the racing/3D route i think i would probably chose the 4 star for sure. I think i would, personally, be happier with the t-34 in my collection.
anyways, thank you so much guys for your advice and input. i feel comfortable i'm on the right track to a successful "career."
John
After reading what you are able to do now except flying inverted, I seriously doubt it would take another 4-6 months. Flying inverted is an easy trick to master and you should have it mastered with practice in another month or so.
I think you will be ok with eh WM T-34. It is very stable, much more than the H9 version. I have flown them both and the WM is more stable. It lands as easy as a trainer honestly, so you will be fine with it. I would advise you to not fly it like your trainer at first because each plane is different and it will handle differently than the avistar does, but you will have no problems with it.
Good luck and take some photos of it when you get her down.
