RCU Forums - View Single Post - pull-pull setup (again, sorry)
Old 07-12-2005 | 08:42 PM
tail strike's Avatar
tail strike
Default RE: pull-pull setup (again, sorry)
Ackerman says the offset should be behind the hing line. Otherwise the non pulling cable will tighten up and thet isn't good.
ORIGINAL: bigcam
Offset which way? If you were to offset the rudder end, would the pivot be behind or in front of the hinge line?
