RE: Showtime
well i just got through twisting and ironing.. all i have to do is wait untill saturday and see if my trim is closer to straight now on the ailerons after flying.. hope so.. it is on the money down both wings now on the meter.... i had to do a little twisting on the ailerons too.
when you get your wing halves together make the root end of the ailerons match the trailing edge then look at the tip compared to the aileron,, both of mine were slightly off. the iron fixed them both
