RE: pershing
when you do the setup procedure, on the throttle channel, either 3 or 2, instead of pull off 100%, try 80%. then DMD will think you send 100%.
then when you flip the throttle to release to idel mode, radio give 120% signal. you should have no problem.
if this dos not work, change a radiol.
good luck.
