RE: starting an inverted engine
MrBass, some engines are easier to start than others, but all will work inverted, or semi-inverted, like yours. You are describing a 135 degree semi-inverted mount. I have had no problems at all starting and running engines in that configuration, & you should be equally successfull --- as long as you use an electric starter for the first start of the day.
