RE: Suitcase Shrike
I have a problem with wing vibration,my .15 shrike has a .25 fx with tuned pipe on it . at about 1/2 throttle and up the right wing starts to vibrate very bad . I put packing tape between ailerons to stop airflow through ailerons. could it be the z bend in control rods to servo? there is a little slop not much but maby enuf to make aileron vibrate causing the whole wing vibrate. Im stumped maby i should replace z bend rod with fixed rod to servo ?only problem is there is not alot of room to do so. [&o]
