RE: Suitcase Shrike
We have a 15 Shrike over here in Egypt that had the same problem. We ended up putting 2 aileron servos out in the wings. Problem solved. What size wire did you use to make the aileron linkage, I would suspect that the rod is vibrating at speed.
