RE: E-FLIGHT BLADE CP
Is the 8T pinion gear available as a replacement part for the supplied 10T pinioned moter or do you have to by a new motor with the the 8T pinion gear on it. If the pinion gear is available separatly is it difficult to remove the 10T gear and replace it with the 8T?
