RE: E-FLIGHT BLADE CP
The gear can be removed with a pinion gear puller. If you don't have a puller, you can carefully split the gear with a Dremel cut-off wheel. Be sure to tape the motor vents so the brass filings can't get into the motor.
Press on the new gear using a vice or press. Check the electric forums for the correct procedure.
