RE: Help! ASAP
Make sure the receiver crystal is on the same channel as the transmitter and that the transmitter batteries are good.
Ensure your motor battery pack is charged.
The servo connection numbers are numbered from front to rear with the receiver crystal side up and the connectors facing to the right. The CH1 connector is straight across from the crystal.
Turn the transmitter on and plug the E S C into channel 3. Hook up a servo to another channel. Connect the battery to the E S C. If you have a switch on the E S C, turn that on.
Hope that get 'er going.
