RE: Help starting a Webra .50
You mentioned that you applied heat to get the throttle body to start moving again. It's possible, depending on the amount of heat you used that you melted/warped the O-ring under the carb and now have an air leak.
I am also assuming that you get the 2 -3 seconds of run time after a prime. That is what makes me believe an airleak. A new glow plug certainly would not hurt.
