RCU Forums - View Single Post - question on angle of force modification
Old 07-16-2005 | 06:33 PM
Jim Thomerson
Default RE: question on angle of force modification
The sweet spot for the rubber to hit the runway is at the end of a line passing through the CG, 15 degrees in front of a vertical reference line passing through the CG. This is for a hard surface. For grass, the wheels need to be a little further forward and I can't tell you an exact figure.
Jim
