RCU Forums - View Single Post - setup questions, basics......
Old 07-17-2005 | 11:34 AM
ELTIGRE
Default RE: setup questions, basics......
you should not generally sand the curved blade side as this can change the airfoil. the last inch or so of your prop does 90% of the work so its critical. the FLAT side of the blade is actually called the FACE of the blade.
