RE: Official HPI MT2 Thread
yea that tank will be pretty much a direct fit. i had to make a longer pipe braket. cuz the tank would get in the way of the pipe. if u put that tank on the stock holes were the stock tank went it will rub against the front dog bone. so put screw it in on the outside hole. ull see what i mean about the pipe hittin the tank. just a longer pipe braket will be fine.
just today my rear dif stripped its not even stripped i took it apart and all it was was there wasent enough shims in there so the gears werent meshing right. the pinion was hardly even touchin the bevel gear. so i need to add shims and itll be fine.
