RCU Forums - View Single Post - steam engine
Thread: steam engine
Old 07-18-2005 | 01:09 AM
Max_TMP
Default RE: steam engine
It's an oscillating steam engine. It looks like it is already assembled.
I cannot see from your pictures, but the oil part probably is for the crank.
All you need to do is connect steam or a constant air pressure to one of those lines as seen in you number 2 post an start the engine turning. If you want it to go in the other direction just change which line you feed the pressure into.
