ORIGINAL: aurora799
-As the the Heli gets light on the skids it starts to yaw clockwise. It takes almost full right rudder to correct it. Is this because the tail is not spinning at enough speed to give it authority yet? The gyro apears to be working -ie. The servo responds when I move the heli manually. Maybe I just have to adjust the Sensitivity & Extent settings on the Gyro?
Using right rudder to correct the heli turning clockwise is all wrong. Always fly the nose. Right rudder
should make the nose of the heli turn right.
I've got the Swallow Advance charger, you can't beat it for the money in Oz. Charges everything...
